RIM BlackBerry  Pearl  8100 Logo
Posted on Jan 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i format my micro memory card - RIM BlackBerry Pearl 8100
Anonymous
Level 2:
  • Expert 101 Answers
  • Posted on Jan 25, 2009
Anonymous
Expert
Level 2:
Answers
101
Questions
Helped
39608
Points
217
Open your my computer select this device right click and at bottom is format drive
1helpful
My 2gb sandisk micro SD card reduce the size after formatting
Possible micro SD bad sectors. To check your micro SD bad sector or not, you use the HD Tune software. To restore the capacity micro SD, which is done is Low Level Format. You can use the software HDD Low Level Format Tool.
How to use HD Tune and HDD Low Level Format, you can see here
Transcend Repair Bad sectors
How to repair micro SD, you can see in here
MMC Repair Without Losing Data Video 2
When i try to format my micro sd 2 gb card it say that it need to be formated but when i click for it format it say windows cound not complete the format
You can format your micro-SD Card using a software which you can download by clicking this link. I uploaded it to my FTP site for you and it will be there for a limited time. Download that file and save it to your PC. Then unzip that ".zip" file.
If you format micro SD card connecting it to your PC via USB port, it may not ask for password. (I think your phone asks password to format.)
To format your micro-sd card:
- First plug in your micro-sd card into you PC.
- Run the downloaded "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your memory card).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
Hope this helps you.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you
I have a 2 g memory card which when full I uploaded to my PC and then deleated all photos from the memory card I tried to use this card again but the camera tells me the memory card is full also it tells...
Exactly the same problem occurred with my San Disk 1GB micro-SD Memory Card. And I solved this problem formatting my micro-SD Memory Card using a software which you can download by clicking here.
- Run the installed "HPUSBFW_2.2.3_MASTER.exe" file.
That's all my friend. This solved my problem and I hope this helps you too.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
I am not able to format my micro sd card.
try to format it using ur phone.. if still showing sum error thn card is corrupted.. it will be replaced
1helpful
8 gig micro sd unable to format
you should download memory retriever it fixes your memory card and retrieves your data. i had the same memory card and i thought it was from the memory card acting up so i got a new one. but it was kind of from both the phone and memory card but i downloaded the program and = ] my new memory card wasn't formatted so now am all good! both of them working because my san disk memory card wasn't working and it deleted all my data. so now it retrieved and now is working! give it a try! and tell me what happens
1helpful
2answers
Cell phone how do you format the sd card?
just go memory card in that u find format option
select that & ur memory card will get format or try connectioning ur mobile to pc & format through pc by selecting memory drive right click mouse button select format option in that asked for quick & custom format select one of them & format ur micro sd card
I can not format my memory card
Make sure that the device you are using specifically is to Micro SD High Capacity format and not just Micro SD. If it says just micro SD on the manuals or on the unit, it can only use a 2gb card.
10helpful
2answers
Memory card micro sd cannot format
Definitely your Micro SD Card has a problem. might be ita a virus problem.
Try to format it by your Computer not by your Phone. If you have a AntiVirus scan your Card and then try to format it.
if you are not successful in one chance Don't afraid at all, try it three or four times by removing and then inserting the Card again in the Computer........
2answers
Memory card
connect the card in memory card reader and got to mycomputer-->right click-->manage-->disk management. see weather you memory size is correct or not if its different right click the memory card and delete the partation then create a new partation
i was done this to my san disk memory card
Top RIM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Kirk Augustin
Kirk Augustin
Kolbrun...
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
