Anonymous Posted on Dec 26, 2012
Initialize developer in sharp 5618 digital copier
I install new machine but idont know how to initialize developer
5 Related Answers
Anonymous
  • 146 Answers
  • Posted on Jan 02, 2008
SOURCE: add developer in sharp AR-5316
That model uses a TD cartridge so when you replace the toner the developer is included. The crum chip on the TD cartridge will reset the counters and sets the developer.
Anonymous
  • 146 Answers
  • Posted on Jan 06, 2008
SOURCE: sharp copier ar-5316
That unit uses an AR-016TD Toner/Developer Cartridge. The developer is changed each time you replace the toner. To remove the drum unit open the right side cover, then the front cover, remove the TD cartridge, loosen the green screw on the front of the developer unit housing just above the TD slot. carefully remove the DV unit without tipping or you will spill out the existing DV. Then you can pull out the drum unit. There may be a green screw on the drum that must be loosened but I don't think so on that particular model. Installation is the reverse of removal.
Anonymous
  • 4 Answers
  • Posted on May 30, 2008
SOURCE: Sharp copier sf 2530 developer reqired error code (ie indicator on)
It's hard to be sure because our model numbers are different but drum reset should be 24-7 and dev reset should be 24-6. Good luck
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Sep 18, 2008
SOURCE: sharp ar5320 developer reset code
The developer doesn't have a reset code.  It uses a calibration program instead with the reset integrated into it.
Even though the copy quality is fine for now, it can change in the next few days.  You should order some developer.
Anonymous
  • 95 Answers
  • Posted on Apr 12, 2009
SOURCE: Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
