Procedure for entering tv codes into wireless keyboard
SOURCE: Remote stopped.
I was able to find the MSN TV Set Up Guide Manual online. Within it was the list of codes for various brands of TVs. One of those for Toshiba TV was in bold print. I used the instructions for entering the code and used that bold printed code. The remote worked both the Toshiba TV and the MSN TV2 unit after that code was entered. Apparently the remote had lost the original code somehow.
SOURCE: RCA universal remote codes
Try this link below that leads directly to RCA and their universal remote controls.
Good luck, CBR2009
http://www.rcaaccessories.com/rcaaccessories/RcaaccessoriesController.do?ACTION_TYPE_ID=ACTION_TYPE_CATEGORY&ACTION_CATEGORY_ID=STR_CATEGORY_UNIVERSAL_REMOTES
SOURCE: how do i manually enter codes?
I think this is the answer, but you will have to check it out. This is directly from RCA. You need the codes for the devices you want to program the remote for, naturally :) This was under a different remote heading but it seems like it has to be right.
Is the ON/OFF key ON? YES: You are done! You have programmed this device key.
is the ON/OFF key OFF? YES: Iit blinked four times and turned off: You have either entered a code number that is not in the code lists or missed a step in the code entry procedure. Try step 3 again.
SOURCE: procedure to code in for rca312w remote to ge televsion
Turn on the TV, press and hold down the TV key, while holding down the TV key enter one of the four digit codes, the LED light should go off, if not, repeat the steps using a different code....hope this was helpful...
SOURCE: What is the code number
You can get the manual on the link below.
http://audiovox2.info/docs/common/RCR312W/RCR312W_OM.pdf
Codes on this link below.
http://audiovox2.info/docs/common/RCR312W/RCR312W_OTHER_CL.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
