SOURCE: Parrot 3200LS won't pair with anything
Try all com ports, eventually one should work, try deleting all paired devices from your parrot, it may be full.
SOURCE: trying to pair my nokia 6303 phone to parrot handsfree device
you may need to delete any existing paired devices from the settings menu to allow for new paired dvices
SOURCE: Parrot Glicches
sometime, it my be in relation with the install.
Just a simple question, did you install it by yourself? if yes, did you connect the mute cable of the kit? cause if you disconnect it and try to make working the kit and see if the mute is working may be the explanation. signal treatment.
(except trouble of the kit), after a while plugging on a 12v dc only can be the explanation. Do you have the message "good bye" on the display when you switch off the ignition key? If not, that could also be due to the fuses inverted to the vehicle between the 12 dc and the 12 ignition. Then you just have to inverse fuses.
SOURCE: how do i pair my
The first
time that you switch on the 3200 LS-Color, you must pair your mobile phone
with the kit. 1.Enable the
Bluetooth mode on your phone. 2.On the
hands-free kit, scroll through the menus until you come to Settings Pair with
phone and select the relevant option for your phone. A 4-digit PIN code then
appears on screen. Memorize it. 3.Then from
mobile serach the 3200 LS-Color device Once the
search has finished, "Parrot 3200LS / Parrot 3400LS" is displayed on
your phone. 4.Select the
kit. Your phone prompts you to enter a code: key in the code shown on the
kit screen and confirm on your phone. 5.The kit's
screen displays "Pairing". 6.Once the
data has been exchanged, "pairing successful" appears on the 3200
LS-Color.
Thank You
