Watches Logo
A
Anonymous Posted on Nov 08, 2012
Broken band on a Berenger Aviator Solid Titanium wrist watch
The bracelet on watch is broken, (it is also solid titanium) how or where can I get it repaired?
5 Related Answers
Anonymous
  • Posted on Mar 28, 2008
SOURCE: Tissot T-Touch T33.7.788.51 Bracelet replacement
Sounds like it's broken @ a factory sealed link (non servicable). Local jeweller should be able to order & fit you a new one
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jul 09, 2009
SOURCE: How do I get the pins out of the titanium band for Casio PAW1500T
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Anonymous
  • 10 Answers
  • Posted on Feb 23, 2010
SOURCE: my gunmetal titanium band (only half of the band
some watches provides bracelet parts to replace, like rado, tissot etc...otherwise you have to replace whole bracelet, as per my experience titanium cant be solder nor repair
Anonymous
  • Posted on Apr 16, 2010
SOURCE: how can i polish my seiko titanium watch
I got very good results using Brasso as directed for polishing brass and other metals including stainless steel, copper, etc. It evidently contains ammonia, oxalic acid, and a light abrasive powder such as is found in car wax. I used it on my $300 citizen Ecodrive Titanium watch that came with a titanium bracelet. The Brasso does a nice job of polishing the crystal as well.
Anonymous
  • Posted on Jul 03, 2010
SOURCE: I own the nike. Lance 4 watch . The wrist band
Mine has done the same. i was looking at this site for the same repair, but i thought it should be quite easy to do ourselves. Simply use a high strength loctite and clamp it in position tightly for a few hours.
I'll let you know how it goes. (It's a bad design - a weak press fit). If the loctite fails then i'll try a metal bonding adhesive.
Top Poljot Watches Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you a Poljot Watch Expert? Answer questions, earn points and help others
