Kenmore 54501 Dehumidifier Logo
Posted on Nov 02, 2017
I have a problem with my Kenmore dehumidifier. I turn it on and I can hear the fan running, then I can hear the condenser start to run. Then about 3 seconds later the condenser shuts off, (with the fan still running). Then the condenser comes on for a few seconds and shuts off again. This continues indefinitely. Model #580.52450200
5 Related Answers
Anonymous
  • Posted on Aug 19, 2007
SOURCE: runs for a couple of minutes and then stops
Try cleaning out the air filter using cold water. I did not even know the unit had one until I had the same problem. Pull out the bucket. The filter is located where the front top edge of the bucket would be located if it were in the instrument. Remove it by pulling straight down. It may be taped to the instrument for shipping purposes. According to the manual, this should be done every month. I have had the machine since Katrina and this is the first time I have had a problem. Hope this helps.
Geterdun
  • 184 Answers
  • Posted on Dec 19, 2007
SOURCE: Dehumidifier shuts off after 2 mins
you might have a compressor problem, in which it won't be economical to repair. if you are using the unit in cold weather then it just might be that there is not enough humidity in the air and it is cycling fast.
Anonymous
  • Posted on Jul 19, 2008
SOURCE: Kenmore 54701 Dehumidifier
I'm working on mine right now as we speak with the same problem , it runs for 3-4 minutes and then drops out and what I think I have found is the compressor comes on but the fan that blows over the condensor/evaporator assemblies never turns on ! I tore the covers of mine and put a volt meter across the orange and black wires (with the unit on high ) , on the little white plug in the metal box on a pc board , that all the wires go into and with the comressor off just before it starts on power up I have 122vac (volts ac) and then the compressor kicks in and it drops to about 107 vac but no fan action so I'm getting on line to order a motor assembly Kenmore # 4681A20040K ! I just happened across this site so I hope It works for me and helps you !
Anonymous
  • 115 Answers
  • Posted on Aug 19, 2009
SOURCE: motor runs fan does not
you may have a stripped out fan unit, the fan motor runs, but the fan does not spin? my fan was plastic and stripped out there should be a flat spot the lines up with shafton motor ifit is round your should replace fan blade unit. i could not find one so i pushed tooth picks in between shaft an fan and glued them has worked for a couple months now
Anonymous
  • 43501 Answers
  • Posted on Jun 18, 2010
SOURCE: Kenmore dehumidifier 580 5370 1300
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Freezing up and bucket not filling
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils. To remedy this problem, you can try any of these: Warm up the room the dehumidifier is in. Put the dehumidifier on a sturdy table (the room air is coolest near the ground).
Turn the unit off until the room warms up.
Good luck
Freesing up and bucket not filling
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils. To remedy this problem, you can try any of these: Warm up the room the dehumidifier is in. Put the dehumidifier on a sturdy table (the room air is coolest near the ground). Turn the unit off until the room warms up.
Take care.
Plugged in, light on, don't hear fan running. What's wrong? On the previous, but same model we could hear the fan running but on the new one we bought we don't hear it.
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
heatman101
1helpful
When the compressor is running, should the fan also be running??
yes
whenever the compreesor is running you ned the fan to run for two reasons
1 to cool the compressor
2 to sling the condensate on to the evap to keep that from building up frost
1helpful
My kenmore dehumidifier compresor runs the fan runs but no water in the bucket . Compresor freon lines both same to have the same tempature ( flow and Return ) . Is a freon charge the answer ?
More than likely not. I would start by making sure all coils are clean, (both evap and condenser) and to make sure airflow is not being obstructed. Most factory charges appliances don't leak refrigerant and therefore should not have to be charged during there useful life. Hope this helps
6helpful
Kenmore 54501
Normal 0 When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
4helpful
Dehumidifier not collecting moisture
1helpful
Kenmore 54501 Dehumidifier Problem
Top Kenmore Dehumidifiers Experts
john h
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
