Kingston 4GB DataTraveler I Generation 3 USB 2.0 Flash Drive, White and Gray Logo
Posted on Oct 27, 2012
WHAT IS WRITE PROTECT?
WHEN WE FORMATE THIS USB SAYS WRITE PROTECT?
Bill Black
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Oct 27, 2012
Bill Black
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
298
Points
19
Look on the side of the usb there is a little button that you push one way or the other to remove the write protect
2answers
Cannot format usb says write protected but there is no write protection for the usb
Reinhard, Check the attached links,instruction and guides on removing USB write protection, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2 ways to fix write protected USB drive or SD card
How To Fix Write Protection Errors On USB Stick
How To Disable Write Protection from USB Key
How to remove write protection on generic usb disk drive
7helpful
2answers
How to reformat a write protected usb?
No need to reformat your write protected USB. The hings you should do is to slide to small button you can see in your USB to remove the write protected.
1helpful
2answers
Usb not formating due to write protect
Some usb pen drives,  if thats what you mean? They have a little button on the side of them to protect the contents of the usb pen drive. Check that, tyhen go to "My Computer" look for pen drive, Right click and format.
 Best of luck.....
2answers
My usb drive is write protected i cant format it pls help....
Have you tried doing it from another PC? If the same problem persists, look closely at your drive and check for a tiny switch that has a lock label on it- it maybe switched to the lock position. Most USB drives has this switch for write protection.
1helpful
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
6helpful
1helpful
HOW TO FORMAT A WRITE PROTECT USB DRIVE
I try to answer this even it is late.
If this doesn'thave any movable switch. Actually very small switch on part of it. You got virus in it. Usually it is hidden, and usually name AUTORUN.INF. run scan to your usb drive.
3helpful
the drive isnt write protected the usbport or the connection is loose so that the computer is showing the drive as read only drive also you can format it using command and also setting off the read only attribute that may have been put by a virus also softwares like usbcillin makes pen drive writeprotected take care
69helpful
7answers
repair_v2.9.1.1.zip
good program. kdt100-4gb now is ok
Top Kingston Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Narseman
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
