For a memory card reader, your computer should have a driver if you are on Windows 7. Most memory card readers are also recognised by MAC computers. The jpg files from your computer should show up on your computer too. If you have an old operating system on your computer, you need a CD that once came with the card reader, because most firms take care you get the drivers for that. You also could try to get the drivers for the card reader when you google on de card readers brand name.
try to put in card reader and connect to PC,if PC recognize your memory card try to take backup of your file in card using icare card pro software..then format the memory card... even PC also not recognize your memory card is dead...
With Windows XP, Vista & windows 7, no additional drivers are required for memory card readers or USB drives. If you are having a specific problem with the memory card then try it in another card reader.
Try to install first the driver for your usb port.... then install also the driver of memory card reader.. After doing that, you can now browse the files on your memory card..
Hope that fix it.
Much appreciated if you rate this solution..thanks
From Device Manager; Right click that Yellow trangle and click un-Install. It will remove present card reader driver from your system. then If you have Card reader Driver CD then install it from CD. Once Driver is installed then insert SD card to check.
Generally card readers will either come with a built in driver, or it would come with a driver disk. You may need to visit the website of the card reader to check for downloadable drivers is possible.
