Hello! I have a kingstone 16 SDHC and a laptop with an SD card reader (not SDHC).. at first i didn't know about SD not working in SDHC reader but it did.. i have format it.. made disc images on it even install linux on it. After i format it in other card reader a chinese one but with SDHC support doesn't wor on my laptop anymore. It apears in win7 but i can't see the capacity, i can't format it,,can't open it and in linux it apears on gparted but can't do nothing. when i'm trying to format it in linux it give me an I/O error on gparted on fdisk and dd. With dd i it tries to wipe it it apears some ( ex: write inodes done , can't write superblocks... ). OK some say dat SD reader can't read SDHC i understad but the problem is that it did and verry good but after format it with an reader with SDHC suport didn't.. i think it had SDHC suport, didn't say anyware on it
SOURCE: Problems with formating samsung e250 micro sd card
Did you try to format the card in the device thru Windows Media Player, or Rhapsody? If so, try formatting it thru My Computer instead. My Computer>Device Name>Right Click and select format. It is most likely NOT a virus if you have only put music on the device. It is most likely a corrupt file, or a database error. Best of Luck.
SOURCE: Memory Card!!!!!!!
format a memory card through DOS mode
GO on command prompt then go on drive of memory card e.g. remove device f
SOURCE: will a SDHC 4G card work inthe c875 camera ?
i don't know if you got my last post (pc playing up,im not going to tell you its the user :))
the answer is no you can only use upto a 2 gig card on this camera
(did a search on the kodak website then phoned them up for you and that's their answere)
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
