GE 29318GE1 Corded Phone Logo
Steve Freitag Posted on Apr 27, 2007
Programming How do I program the speed / memory dial?
  • 1 more comment
  • danie36 Nov 23, 2007
    Programming problem
  • Anonymous Dec 30, 2007
    having problem storing names and numbers in memory
  • Anonymous Apr 02, 2008
    20391 GEI-A
A
Anonymous
MEMORY
Store as many as 12 numbers in memory for easy dialing. Three can be stored in the Emergency Quick Dial locations, and nine additional numbers can be stored in the numbered keys (1-9).
STORING A NUMBER IN MEMORY
1. Press SPEAKER (or pick up the handset).
2. Press STORE.
3. Dial the number to be stored (up to 16 digits).
4. Press STORE button.
5. Press a Memory Location (1-9 on the keypad), or an EMERGENCY QUICK DIAL button.
6. Press SPEAKER (or hang up the handset).
7. Record the phone number on the memory directory (located under the plastic cover).
ADDING A PAUSE TO THE DIALING SEQUENCE
Use the REDIAL button to insert a delay in the dialing
sequence when storing a number, for example, when you need to dial 9 to get an outside line. Press REDIAL at the point in the dialing sequence in which a pause is required.
CHANGING A STORED NUMBER
Change a stored number by replacing it with a different
number.
DIALING A NUMBER FROM MEMORY
You can dial numbers from memory when using the handset or speakerphone. When you get a dial tone, press the MEMORY DIAL button followed by the memory location (1-9) for the number you want to dial.
Top GE Lands Phones Experts
Darran Hatten
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
