Hello Manuel sorry for your machine to be in that stake but have you tried to check on that paper conveying motors because that error is for those lift motors try to go on your machine run this code
press status/job cancel
enter 1087*2 twice
enter 906 and then you will see execute
the you press start to see whether it will stablize
SOURCE: error code 260 for a MITA DC 6090
its a problem in your cooling and drive system... consult kyocera for an explanation of this code...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: MITA copier DC-2360, error code C610, fuser
IF you have corrected the problem that caused the C610 (broken fixing heater wire), then the error is cleared by turning the machine power switch off then back on.
