Whirlpool Calypso GVW9959K Top Load Washer Logo
kyh smith Posted on Apr 23, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ld light when i turn the washer on the ld light comes on
  • Anonymous Mar 18, 2014
    WHILE THE WASHER IS GOING IT WILL NOT CYCLE THRU THE LD LIGHT COMES ON AND IT QUITS
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 08, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
165
Points
If there is a clog and a snake will not work or you do not have a snake you could try a 'backwash'.
The normal drain pipe goes from the drain to a tub at the base of ther washer. The drain may be clogged in the line or at the base insiode the tub. By fixing your cold water hose or your garden hose you can force warer in the oppostie direction. A coiple of winds of electrical tape will hold the needed pressure.
This will work if the clog is a build up of material lint or other debris. Normally this will break up the clog and allow it to be discharged a little at a time. If the clog is as a result of a solid object, the 'backwash' will not work or may only be a temporary fix.
Try a normal wash with only a few items to check if it worked.
Geoff Siegel
Level 2:
  • Expert 164 Answers
  • Posted on Jun 16, 2007
Geoff Siegel
Expert
Level 2:
Answers
164
Questions
0
Helped
122925
Points
252
If the clog is not in the pump or in the drain line it could be in the tub where the water drains out.
Anonymous
Level 3:
  • Master 5,911 Answers
  • Posted on Apr 29, 2007
Anonymous
Master
Level 3:
Answers
5911
Questions
6
Helped
2785796
Points
22414
Ld is a "long drain" fault. If it takes longer than 5 minutes for the water to pump out, the operating pressure switch will reset. Check your drain pump and/ore drain lines for a clog.
  • Anonymous May 08, 2007
    If you're going to rate my advice as "Poor" it would nice to know why. Any comments you could add about what you have tried would help in providing you with a better solution.
Narseman
