Di250 model, press print starts to copy(actualy reads paper being copied) as machine starts to run copy process it stops and error code c1300 appears. This started after a paper got jammed. If all paper is removed how can/ where is the reset switch (or is there one)Di250 model, press print starts to copy(actualy reads paper being copied) as machine starts to run copy process it stops and error code c1300 appears. This started after a paper got jammed. If all paper is removed how can/ where is the reset switch (or is there one)
You can't post conmments that contain an email address.
· These malfunctions are concerned with faulty symptoms as they relate to software, hardware,
and communications. For remedial actions, change the board, check for cable connections,
and turn the Power Switch OFF and ON.
(6) C10]] to C13]]
C1300 1. Reset the malfunction and turn OFF and ON the Power Switch.
2. If the same malfunction persists, check the harnesses and PJs between PH
Unit and PWB-A and, if they are intact, change PH Unit or PWB-A, in that order.
