Seagate Freeagent Goflex 500 GB USB 2.0 Ultra-portable External Kit and USB 3.0 Adapter S... Hard Drive Logo
Posted on Sep 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix parameter incorrect
Sorry I'm really a dummy with pc's. Get the message parameter incorrect - how do I fix. Can I still recover my files?
Brian Sullivan
Level 3:
  • Seagate Master 27,725 Answers
  • Posted on Sep 18, 2012
Brian Sullivan
Seagate Master
Level 3:
Answers
27725
Questions
Helped
5776703
Points
79191
You must be logged on as an administrator to perform these steps.
If you don't like the letter Windows has assigned to a new drive or you want to organize your drive letters in a certain way, you can change the drive letter.
You can assign the letters C through Z to each drive on your computer.
A and B are usually reserved for floppy disk drives, but if your computer does not have floppy disk drives, you can assign A and B to volumes.
You can see which drive letters are used on your computer by opening Computer.
Open Computer Management by clicking the Start button, clicking Control Panel, clicking System and Maintenance, clicking Administrative Tools, and then double-clicking Computer
Management. If you are prompted for an administrator password or confirmation, type the password or provide confirmation
In the Navigation pane, click Disk Management
Right-click the partition or drive that you want to change, and then click Change Drive Letter and Paths.
Do one of the following
To assign a drive letter if one has not already been assigned, click Add, click the letter that you want to use, and then click OK
To remove a drive letter, click Remove, and then click Yes to confirm that you want to remove it.
You might need to do some diagnostics to find out what is wrong.
If you have nothing to lose, format the machine.
or
You have to erase the entries from the Registry. Run RegEdit.
Source(s):
click start type regedit press enter
or
Use the registry editor and find the key:
HKEY_LOCAL_MACHINE\SYSTEM\MountedDevic...
F: as in whatever drive you want to change, and then just change F: to G:
or
If the installation is being run from a network location or if the installation is being run from a directory structure that is several levels deep
(resulting in having too many characters in the path name), this error may occur.
Follow these steps to fix this error:
Copy all the installation files (setup.exe and all other files in the same directory) from the network location or source media (such as the CD) by pressing Ctrl + A or Edit > Select All.
Create a folder on your local hard drive (e.g., Desktop) by right-clicking and selecting New > Folder.
Paste (Ctrl + V) the installation files into the folder.
Double-click setup.exe to run the installation locally.
If the scenarios above are not related to or did not resolve this issue, the error might be caused by something specific to your computer.
The following general troubleshooting tips might help resolve the issue:
Clean the Temp Directory
Install ikernel
hope this helps
1 Related Answer
sodeep
Sudeep Chatterjee
  • 3269 Answers
  • Posted on Nov 17, 2010
SOURCE: hdd detected however error message incorrect
right click on 'drive'
go to properties
click on security
click on your user name in the upper window
and in the lower window select all check box allow
click on apply button then ok
it will work definitely
plus
from explorer, right click the hard drive and properties, and in security tab, click full access for system & users
However if proper drivers are not available then download it from
http://www.seagate.com/ww/v/index.jsp?locale=en-US&vgnextoid=1b0cfbbad0f89210VgnVCM1000001a48090aRCRD
Top Seagate Computers & Internet Experts
Narseman
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
