JVC Everio GZ-MG130 Camcorder Logo
Posted on Dec 25, 2008
Error Code: FF052102
I have burned DVD's before and had no problem. I also tried to burn DVD again thinking that something was wrong with the disc. No luck. Same error code. Tried burning new material and it works. What's wrong with my other material? I have the same problem. Worked well for 4 or 5 times and then it went wrong. Still no solution found?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1222
Points
SOLUTION FOR THIS ERROR: FF052102
Anonymous
Level 1:
Scholar:
  • Contributor 44 Answers
  • Posted on Jan 02, 2009
Anonymous
Contributor
Level 1:
Scholar:
Answers
44
Questions
Helped
20402
Points
98
This have happend to me before when I first realized that I was using a CD instead of a DVD then I did the DVD then it continued to happen so I tried one more time and used a whole new disc......so.. Change the disc and see if that helps. Make sure your using DVD-R, DVD-RW to burn you disc, Dual layer disc will not work.
Let me know if that helps..
>>>If I have helped you, please don't forget to rate<<<
Anonymous
Level 1:
New Friend:
  • Posted on Nov 08, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1222
Points
I generally backup the video's i just took from the camcorder to the computer. Then I select ( checkmark ) the videos to be burned to disc. Never had a problem. This time I filtered the selections by date ( because I now have 400 on back up ). When I tried to select just the recent videos to burn to disk I kept getting the FF052102 error message ( annoying ) - I then went back and selected the files to burn with via the entire backup library and had no problem. Worth a shot.
1 Related Answer
Anonymous
  • 122 Answers
  • Posted on Aug 23, 2009
SOURCE: Error Code: FF052102
wrong burning format most likely
Top JVC Video Cameras Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
