Don't have a manuel and we can not figure out how to program the tv to receive the channels from our cable
Here is where I found the remote code (1256) for the TBX-2000AF and it has many more codes for Polaroid models. Good luck (copy and paste this link) http://polaroid.custhelp.com/cgi-bin/polaroid.cfg/php/enduser/popup_adp.php?p_sid=fPLB5Gzi&p_lva=&p_li=&p_faqid=2854&p_created=1116267791&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0xOTk0JnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MQ**
Here is some info to program a DirectTV remote for the Polaroid TBX-2000AF combo TV. (My Direct TV remote control has the number RC32 at the top left next to the device selector switch (not sure how many different DirectTV remote types are out there.)
Push the device button over to TV. Press the Mute and Select buttons at the same time and hold them until you see 2 flashes near the top of the remote. Press 11256 and then the SELECT button (It required the extra 1 in the number before it would program, I found this by luck). Now try using the volume button on the Direct TV remote to verify a good program. Push the device select button back to "D". If it did not work the first time try it again, these things can be a bit finicky.
Go to polaroid and get the telephone number (1-888-312-2515). I got this number there, I had the same problem. They email me my manuel. Hope this helps.
I found a fix if you have a polaroid tv model # TLA040 (thats the 40 in flat screen) if you have direct tv and your remote for the direct tv does not work your tv. follow the directions to program remote on the dtv then stroll down to the maker samsung follow the directions but type in the code 10056 this should solve your problem! it works for me!! enjoy!
Here's the user guide; http://www.polaroid.com/service/userguides/ce/tvs/tbx2000af_ug.pdf - please ask again if you need more info - here is the link for the product page if you wnat to look for more help from polaroid; http://www.polaroid.com/global/detail.jsp?PRODUCT%3C%3Eprd_id=845524441763523&FOLDER%3C%3Efolder_id=282574488338773&bmUID=1176642785129&bmLocale=en_US Hope this helps :)
Select the meniu end go to the instal automathic
i rented a tv from rent a center which is a toshiba it not picking up my cable channels the remote want work
Have a Hitachi TV/VCR combo and cannot program channels. I do not have the original remote nor a manual. Thank You.
scan channels
need codes to program cable remote
no remote can/t change channel
Do not have a manuel and do not know how to program to record from my TV
