Hi my washer wont start the dispencer drawer front came off and it wont stay on.Now the washer wont start and it gives an error ddo on the display
Ok, I got mine to work. Push the button down on the back side of the soap dispenser that says push down or push here (to take the tray out). When you have it out you will want to turn it over and there are 3 or 4 white tabs. You will want to pop the front part of the drawer off and then on the bottom about an inch in/down there is a small slot to put it into. It is the same size as the magnet and the magnet goes with the squares on the top and bottom. You cannot actually see the magnet when the drawer is put back together. When I talked to the service man he said they did away with the magnet on the new model. How stupid to put it there to begin with!! Hope that helps and if it doesn't ask again.
I found it on the right side of the drawer. pull it out and look for a space that is big enough for the magnet to fit length wise
You can also cut the sensor off inside the control panel and short the wires together. The replacement control boards have it shorted and ask you to discard the old sensor
The dispenser drawer has a magnet in it that has to line up with a sensor. if you can put the drawer back in that will solve the problem. if the magnet isn't lost.
ddo error message washer wont start
I push the start button and all the lights come on but no cycle starts. About after 30 seconds the ddo error code is displayed.
ok, our magnet fell off and I found the magnet, but don't know exactly where if fell out of. Can someone tell me???
I just had the magnet fall out of my dispenser drawer and the ddo error began. I just can't see where the magnet is supposed to be. Does anyone know? Thanks!
