Hi if you forget the security code try default code like 0000 or 1234 to reset your mobile if it didn't help you then visit unlocking4free.com here they generate master reset code for some nokia and alcatel mobile model at free of cost.
SOURCE: Forgot my security code
The default security code for Nokia is 12345
IMEI: 356438012346609
Master code: 0631367461
Close all applications on your phone.
With your phone switched ON, remove the battery.
Then remove the SIM card.
Replace the battery without the SIM card and switch your phone on.
Type in the security codes (any code) until the phone request the Master code, when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only.
If it does not request the Master code, your phone will have to be connected to a computer via an unlock box to restore the Security code.
SOURCE: unlock security code for nokia3110c
Hi sir, i have nokia 3110c and i have forgot the security code which i had changed from default i.e 12345..and the new security code i had forgot...please help me out to unlock mine phone as if i have mine important contact numbers and data in dat phone pls help me out for this...
SOURCE: How to resets security code for Nokia 2630
Hi Friend,
The Security code for the IMEI Number Provided is as follows,
IMEI:359342/02/638999/2-------Security code:0511247554
IMEI:356997010391586----------Security code:6725275455
Check it and revert back
Regards,
Ayyasam
SOURCE: I forgot my security code Nokia 5310
Hi Friend,
The IMEI number you have provided is not correct ,From the below link u can
collect the security code by providing your IMEI number,to get the IMEI number umust
just*#06# or at back side of the mobile u will have serial number is as same as IMEI
Number,
http://mastercode.nokiafree.org/
or
if these all not supported then kindly inform it to your serviceprovider,they will make a reset to your security code from their backendprocess,since they keep all the codes in a secure manner.
Kindly check it and provide the status
Thank for using Fixya
Regards,
Ayyasam
SOURCE: i forgot my security code for my nokia 5310 imei (352072023337804
be sure you have software of either twister or jaf. there you can create new imei.
