The digital frame only has 8mb of Internal memory, And if you’re using a high-resolution camera that means you’re only going to get a few pictures loaded into the internal memory. You would be a lot better off playing your pictures directly from the CompactFlash card. Once you place a flash card into the frame it automatically should go into a slide presentation mode and then you should do is hit play.As far as loading it from your computer you need to get a mini USB cord and connect that to the computer and the frame. Once the computer recognizes the frame you can do the transfer.
SOURCE: Westinghouse DPF-0802 does not display all photos on my SD card
You need to download them onto the frame
