Error code CPU Over Temperature Error press F1 to continue
SOURCE: ASUS P5KPL-AM CPU fan connection.
You should still be able to connect the 3 pin connector of the fan to the 4 pin connector on the mobo, the keying tab is offset so that you cannot connect it to the wrong pins.
If you still don't want, or can't connect it there, simply go on the Bios (press delete after you turn on your computer) and you will find an option to monitor CPU fan speed.
If you need any more help, let me know
Alex
www.CAS411.com
SOURCE: intel cpu ucode loading error
does your cpu?boot up?try to go at the cmos!!then load bios defaults?
