Logitech DevCheck 5.33.14 started - 08/09/12 05:58:40 Device 00801014 'Generic Mouse' minterm list not loaded Problem code 1110 (ProblemDeviceNotStarted) Problem: Device has all its UMDs created but device is not started in KHAL. --------------- Device 00700830 'Generic Keyboard' minterm list not loaded evice 00700830 'Generic Keyboard' minterm list not loaded Problem code 1110 (ProblemDeviceNotStarted) (ProblemDeviceNotStarted) Problem: Device has all its UMDs created but device is not started in KHAL.
SOURCE: Wireless mouse and keyboard not working
If you have got a USB receiver for the wireless keyboard and mouse, then the solution might be with the receiver. Normally we know that to play a USB thumb drive, we simply plug in and play. But some model of Acer computer require us to press the button on the thumb drive to activate it. The model I had (an Aspire model) set the press button same as the blicking light bulb. So (a) turn on computer, (b) plug in thumb drive receiver (c) press button on the drive, (d) press "contact" button on the mouse and keyboard. That works for me.
SOURCE: Logitech wireless mouse and keyboard
Normal
0
Press the Receiver button (and the lights will start
flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT
button on the back of the board to connect the keyboard to the
receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button
on the back of the mouse to connect to the receiver. Then they
should work okay.
Hope this helps. Bud
SOURCE: logitech cordless mouse and keyboard installation
You probably already done this but try pressing the receiver button and while it is flashing turn the board over and press the small reset/connect button on the bottom of the board and also the reset/connect button on the bottom of the mouse. It should work okay after that. here is hoping that helps. Bud
SOURCE: Logitech CE0560 keyboard and mouse; first keyboard
First put new batterys in the mouse and key board. if you don't have a tester use a flashlight. pen light. push the remote pickup. light will blinknext push key board button and the mouse next. then try it and see if it works.
sometimes do the mouse first, Then the key board
SOURCE: Microsoft Laser Mouse 5000 stopped working altogether
Make sure the batteries are good and then follow these instructions.
Normal
0
flashing.
receiver.
should work okay.
