A
Anonymous Posted on Jul 31, 2012
Error code 005-301
Getting an error code of 005-301 on my Dell 3115CN Printer. It says "Close ADF cover 005-301." Checked and all of the covers are cosed.
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Dec 18, 2008
SOURCE: my mp600 keeps saying close inner cover-which is closed
I had the same issue, turning off didn't solve it.
There's a plastic flap the width of the print tray just inside that I flipped up and it solved this problem. It is directly in front of the ink tanks. I'm assuming we flipped it down and forgot about it. It seems it needs to stay up, although you wouldn't notice it when it flips down when you close the top, as it closes just fine with it down. It's easy to overlook. This took me a few hours to realize.
The top of the flap has a half circle cut out of it in the middle.
Anonymous
  • 1913 Answers
  • Posted on Mar 21, 2009
SOURCE: I have a Kyocera FS-2000D printer that will not print
first turn off your pritner power.
check open the front door pull your ink cartridge then clean dust and blur from it then check there is not any paper jam then refix ink cartridge.then turn on the power.
Anonymous
  • Posted on Oct 29, 2010
SOURCE: My printer is a Canon
I had the exact same problem. The Alarm light was always on and the screen said "Document in ADF. When I pressed "OK" it would read "Eject the document". Even after I placed paper in the ADF and the paper would feed the document through it, the error and the Alarm light was still there. I found the solution, Lift the cover to expose the flat bed scanner glass. Under the cover, there is a long white bar with two white tabs perpendicular to the white bar. One of the tabs was retracted. Pull on the tab until it is fully extended. The alarm turns off and there is no longer the error. Simple solution to a damn annoying issue.
Robert Kitaji
  • 1335 Answers
  • Posted on Dec 05, 2009
SOURCE: getting "inner cover is open" message
The inner cover is a flap on the inside in front of the carriage when it is at rest when the cover us open. You had to flip the inner cover down to access the ink cartridges.
Open the cover. The inner cover is in the center and need to be flipped up.
Good luck.
rickbrashear
Ricky brashear
  • 176 Answers
  • Posted on Jan 28, 2011
SOURCE: Message on my window: Error -
https://www.canon-europe.com/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MX_series/PIXMA_MX870.aspx?faqtcmuri=tcm:13-716137&page=1&type=faq
here is a website that tells how to correct jams and also shows some pictures of all the door openings, It sounds like the cover that holds you bulk paper, sometimes there is a lid on top of it. it may not be seated properly.
hope this helps
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Rommel Balcita
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
