Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Logo
Posted on Jul 09, 2017
CL code light on
New fridgidaire dishwasher - tried turning on just get CL code that flashes, latch shuts good. tried test cycle, no error codes - how long should it stay on 1 when in test cycle etc.....- heard it could be seal?
I can go manually through each test cycle 1-8 seems to work no error codes. when done test try it again get flashing CL code can hear motor but not water - but in test get water in appropriate cycle - help!!!!
4 Related Answers
ginko
Ginko
  • 19396 Answers
  • Posted on Oct 24, 2008
SOURCE: Electorlux dishwasher flashing CL
Error CL means that the child lock had been activated.
To unlock the machine you should put your finger up inside the handle and locate a slider switch, then push the switch to to the left side.
joe_lishman
Joe Lishman
  • 192 Answers
  • Posted on Mar 22, 2010
SOURCE: Fridgidaire FDB1250REC dishwasher comes on, fills
This seems to be the "anti flood" device at the base of the washer is triggered due to water at the base of the washer. This safety device consists of a polystireene float and a micro switch that detects water leaks/spills and automatically puts the washer in pump out mode. You need to find the leak (hose or clamp)dry the base and rectifythe leak it before the washer works.
Anonymous
  • 1430 Answers
  • Posted on May 21, 2010
SOURCE: Flashes "CL" to close door when it is closed and won't start
The door switch has failed. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the process will be the same. You can also enter your model # for diagrams and illustrations of your specific model.
Anonymous
  • 4323 Answers
  • Posted on Nov 26, 2010
SOURCE: On the display is a flashing CL, according to the
Hi
Error CL appears when the dishwasher control detects door switch is open or door is open. You'll have to open the door and check the continuity of the door switch. If the door seems to be closed then it is the control has detected an issue with the door latch. Check the door latch & seals to make sure door is closing fine. Unplug the dishwasher from power outlet and wait for 10-15 minutes. Restart the dishwasher and check if the error is still there. If error still appears then you'll need to repalce the door switch/door latch. Hope this helps... Please post back for further assistance.
Daniel
Top Frigidaire Dishwashers Experts
Paul Bade
jdthefixer
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
