Chicago Pneumatic  1/2" Air Impact Wrench Logo
Jm Berger Posted on Jul 24, 2012
CP 734 Trigger Broken
Need to find a trigger for the CP 734. This is an old wrench but works great. Don't want to throw away just because of a broken trigger. I think the part number is; CA099927
Eddie Tucker
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Nov 13, 2012
Eddie Tucker
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
5464
Points
25
If you are still looking for this part I would call power tool repair at 330-630-0022 and order that part number. From the breakdown it seems you have the correct part number
3 Related Answers
duane_wong
Duane Wong
  • 6827 Answers
  • Posted on Jan 21, 2011
SOURCE: model 734 1/2 in impact.wont
Yes, if you take it apart you'll find that the trigger isn't allowing air to pass through to the veins of the impact wrench. It's a relatively simple mechanism, where maybe something is broken inside.
If it were blowing air but the veins were stuck, I would say, lubricate it. But, if no air goes through it at all, then the trigger housing houses the problem part.
Have you tried to disassemble the air wrench?
Anonymous
  • 14 Answers
  • Posted on Jan 17, 2009
SOURCE: My 1/2" CP air wrench just blows air thru when I pull the trigger
I have ran into this many times, even though you keep it oiled dirt can and will get inside. what you need to do is unscrew the 4 alen head bolts and pull the nose off. You will see a shaft that looks kind of like a crankshaft with 5 or 6 flat carbon fiber plates sitting loosely in groves around the shaft. pull those out and clean them with solvent and check them for damage or wear. clean the inside of the gun with solvent or brake cleaner, reassemble and it should work fine. If the plates need replaced then you should be able to order them from a tool supplier,and they are not that much.
Anonymous
  • Posted on Aug 17, 2009
SOURCE: sand has entered my CP734 impact wrench.
Check the following website. It is a pdf file, so you will need Acrobat Reader, which is available on this website. After it loads, it lists various CP model numbers on the left side, so scroll down to 734 and click on it( it says 734 OBS) and it will open an exploded view of the breakdown of the CP 734 impact wrench. On the Acrobat toolbar, you can expand the picture as much as you want to and print it.
Good Luck!
Top Chicago Pneumatic Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Anonymous
Level 1 Expert
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
