SOURCE: code 28 i already downloaded the hotfix from microsoft
Just run windows update which will tell you that new updates are ready to be installed. Click O.K. Re-boot when asked & your done.
Testimonial: "okey i will try this on Tuesday coz' the problem is with my offcie workstation. Thank you very much.. More power to fixya.com and to you.. "
SOURCE: error problem while downloading updates
1. Before doing anything else, write down the .NET Framework versions which
are already installed:
How to determine which versions of the .NET Framework are installed and
whether service packs have been applied
http://support.microsoft.com/kb/318785
2. Now see Resolution Method 2 in http://support.microsoft.com/kb/923100
(ignore the title). After running the appropriate/needed tool, (re)install
all .NET Framework versions manually using the download links on the page.
SOURCE: Security Update for Microsoft Excel 2002
Uninstall any MS Office that is currently installed in the system and reinstall it.
SOURCE: I have a new DotS
First make sure you are login with administrator rights. Check the windows firewall and antivirus firewall turn it off. Check the router firewall. Add your web sites in trusted zone in mozila if you face this issue with mozila. Let me know if you need further assistance. Thanks for using FixYa.
SOURCE: windows update error code 8024a000
o overcome his error do the following.
Good Luck!
