Televison & Video Logo
Annette D Posted on Jul 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Main bd what is a main bd
Level 3:
Top Expert:
  • Astar Master 76,851 Answers
  • Posted on Jul 17, 2012
Astar Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15380470
Points
237768
What is the brand name and model number?
Front LED just Cycles white then goes red. Replaced lamp did not fix set. Found 5 volt power on command missing from Digital bd to DMD bd. Need to replace Digital main bd. Part needed is 6871VSMS28B. Will...
Good day!!!
if the command signal from main board to DMD board missing the problem could be the main board..
I already found the board online for only $75 on this site http://www.discounttvparts.com/6871VSMS28B_p/td-1169.htm
$100 on this site http://www.ebay.com/itm/NEW-LG-MAIN-UNIT-6871VSMS28B-6870VS2273C-/260877125964
Hope it helps..
just add a comment for any follow up questions..
Thank you
Samsung hp-t5054 plasma - no picture or sound - beeps at power up- has power - funny electrical smell when pluged in.
You will need to have a good tech check the set out.
There is no way to know what part/s have failed. Parts that fail are the Y-Main bd, Power Supply, X-Main bd, Y-Upper Scan bd and Buffer bds. Last is the Panel has shorted,causing a cascading component failure. Very expensive if that happens.
Top half of my screen goes white and pink intermittantly. All channels. HDMI input. Samsung 42 Inch plasma
First try using Component cables instead of the HDMI cables and see if that fixes the problem. If it does then you have a bad HDMI cable. If it does not then you might have a bad Y-Main bd or X-Main bd or a Main bd. It can also be bad buffer bds. Have a trained Samsung tech look into the problem.
2helpful
Samsung tv model no LE40R74BDXIXEU TV IS USUALLY
First the main bd controls the "Turn on" sequences". When you press the Power on button the Main bd sends a "Turn on" signal to the Power supply. The clicking you hear is the Power on relay ativating. If the tv does not turn on and the relay keeps clicking then you might have a bad Main bd or there is s shorted board somewhere else in the set. The Power supply can also be bad. Have a trained Samsung tech troubleshoot the set.
SAMSUNG LNS3251DC - RED POWER LIGHT IS ON BUT TV NOT POWERING UP. WHEN I PRESS THE POWER BUTTON NOTHING HAPPENS. TV HAS A DARK GLOW COMING THOUGH
Multiple causes here. The Main bd controls the Power supply. The Main bd receives the "Power on " signal from the IR sensor and the Power Button the tv. Seems that the Main bd is not sending the Power on signal to the Power supply. So the first place to start is with the Main bd. Second being the Power supply. have a trained Samsung tech troubleshoot the set.
Screen blacked out and the blue light flashes 3 times when turned on and still no picture.
There are a number of causes. First, The Main Power Supply is bad. Second the the X-Main bd or the Y-Main bds are bad. Third, the Main bd is bad. Have a trained Samsung tech troubleshoot the problem.
1helpful
Poping sounds on start up then went dead
There can be any one of the following failed parts. The FET'S on the Y-main bd have exploded and may have taken out the Main Power supply as well. The Y-Main Upper Y-Scan bd may have some blown up IC Flat pacs which will cause a chain reaction taking out the Y-Main bd and the Main power Supply. The X-Main bd could also have failed. It is best to have a trained Samsung tech troubleshoot the set to find the bad parts and repair the set.
Kyocera KM-1510
BD steady-state problem • BD steady-state problem is detected. (jam code 98)
BD steady-state problem • The VTC detects a BD error for 800 ms after the polygon motor rotation has been stabilizad.
Poor contact of the connector terminals. Defective LSU. Defective main PCB.
Check the connection of connector CN18 on the main PCB and the continuity across the connector terminals. Remedy or replace if necessary. Replace the LSU. Replace the main PCB and check for correct operation.
No picture
This problem sounds like a failed control pwb. This is somewhat difficult to replace and the the back must be removed, and the control bd is located underneath the main digital bd. assy. The main bd is the bd with all the inputs.
Top Astar Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
