Kyocera Mita KM 1530/ 2030 Copier Machines Compatible KP23153 Black Toner Cartridge 106153 Logo
Anonymous Posted on Jul 02, 2012
Error code C620 - Kyocera Mita KM 1530/ 2030 Copier Machines Compatible KP23153 Black Toner Cartridge 106153
  • Anonymous Jul 02, 2012
    low fuser temperature
Error c620 km 1510 how do i fix?
hello error concerns that there is insufficient fusion temperature, heat lamp revises open position and condition of the thermistor and thermostat connections general..etc
1087 1087 to enter with pressing (163) / print> stop / clear you press (001) and ready.
Kyocera km -2030 copier error code C620 how do i clear it and make it to start copying
Try this:
Press and hold stop, start, and left exposure key in that order.
Release and press stop again. Use zoom keys to enter 163, press start.
Exit the mode by entering 001 and start, or power off/on.
Error code c620
action: HD cable plug out & in
I have a dell d620 laptop that is showing a 1000-0146 code can i fiw it at home my self and how
dbarger1367
Unfortunately the error that you getting means that there is a problem with the hard drive. So you will need to replace the drive in the system.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Hi ive got a Dell Latitude D620 laptop i keep getting error code 1000-0146 dst log containd previous errors,is this hard drive dead? if so will it need an IDE or SATA hard drive dont know much about this...
mazaroonie82
Unfortunately the error that you getting means that there is a problem with the hard drive. So you will need to replace the drive in the system. Note the D620 uses a SATA drive.
Issken
Error c620- I tried to copy on a piece of Tyvek (plastic paper) and it melted. I pulled it out using pliers and now I get this error message
are you sure it is 620? not 6020 or 6200?
try hitting 1087 two times on the keypad, that is maintenance mode now type 906 and start button or execute and start button. that will reset a fusing code. that is the only way to reset those codes for safety reasons.
3helpful
2answers
ERROR CODE C630 ON KYOCERA KM-1510
this is a fuser error meaning that the fuser has overheated. In most cases the thermal fuse or thermostat blows and will need replacing. especially if you get the 630 code, and switch the machine of and back on and get a 610 code.
3answers
Copystar CS-1810 Error Code
I'm sorry, Copystar is not a brand I am familiar with.
Be blessed.
Top Kyocera Office Equipment & Supplies Experts
George Mclaughlin
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
