My hyper extension treadmill jn 1360 starts then show error 3 and stops How do i fix this
1) lube the deck belt
2) lube the rollers bearing
3) measure the voltage input motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block diagram.
God bless you
SOURCE: my hyper extension machine jn 1360 walking machine
I believe the underside of the magnetic key (the one that stops the machine if you remove it) contains an electronic component that becomes faulty. The machine "thinks" the key is not in place even though it is. My solution was to take the console apart and bypass the faulty component (DO NOT try this unless you have a basic understanding of how NOT to be electrocuted and how NOT to cause fires, shortcircuits, and/or general mayhem). The alternative is track down an electronics repair type person to do it. BUT the
downside for me is that I've lost that instant stop function when you slip/fall/etc.
SOURCE: My Hyper Extension 1360 model is diplaying a error
hi im wanting to know if there is anywhere that i cld buy a orange switch its to turn the readmill on and off
