Computers & Internet Logo
A
Anonymous Posted on Jun 28, 2012
Illustrator CS5 does not recognize my graphic pen, wether with the Wacom tablet or my new Monoprice tablet. It draws a yellow sticky note kind of thing, it is annoying and I can't find a solution,
When drawing, the pen seems to draw on a yellow sticky note with line on it, when I release the pen, the sticky note disappears with the lines or anything I am trying to draw………
Talya Shachar-Albocher
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 07, 2015
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
447
Points
I too have a tablet not made by Wacom. For some reason, Illustrator only opens the tablet-sensitive definitions for Wacom. The solution I found: Go to the Wacom site, install the latest intuos driver. You won't be using it, but it will trick Illustrator into thinking there's a Wacom installed, the definitions will be active for your pen. Mine seems to work fine now.
5 Related Answers
Anonymous
  • Posted on Mar 19, 2009
SOURCE: pen tool not actually drawing
I also solved the problem by installing the driver from the website. The trick was to uninstall the old driver first.
Anonymous
  • Posted on Aug 17, 2009
SOURCE: drawing problem in PS cs4
Go to your Brushes.
Click on the Brush Tip Shape tab.
Make sure the box is ticked that says 'Spacing' and set it as low as you can (1%) for the smoothest effect.
Anonymous
  • Posted on Sep 17, 2009
SOURCE: Wavy lines when I try to draw straight lines.
same too me.on my old pc.that center thing was working fine.there wasnt any vibrtion at mouse pointer.i cant explain but i know same problem here..mouse pointer slips
Anonymous
  • 4 Answers
  • Posted on Jan 19, 2010
SOURCE: Pen keeps drawing when I lift it off tablet
This problem commonly occurs due to a stuck "nib" sensor (the sensor that detects pen pressure).
Take out the "nib" (important, so the sensor isn't damaged further) and whack the pen on your desk (or drop it on the floor from 3 feet up). It re-seats the "nib" sensor when it's stuck. If this doesn't work after multiple attempts, then the sensor may be too damaged.
Anonymous
  • Posted on Feb 21, 2010
SOURCE: Wacom Bamboo Fun Tablet-Mac. Yellow box pops up under pen cursor.
Your tablet is set under the handwriting setting. Go to system preferences and select ink under hardware. Then turn off handwriting recognition.
Top Wacom Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
