6LO80LO
The hardware that you are trying to access is damaged or failing. The device drivers for the hardware are faulty or incompatible. There is a connection problem such as a bad cable click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions
One bad lead can cause a computer to continue on a cycle to shutdown or fail to detect a hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Do you actually read what you are pasting? Cause I'm not sure how he's supposed to do any of this part that you wrote if he can't even access the drive during setup:
"click start control panel administration tools computer management device manager scroll through all of your devices
if you computer came with a motherboard disk the drivers could be on it"
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
Do you have the jumpers set correctly for your setup? Check it against the diagrams on this pdf:
http://eshop.macsales.com/Tech/manuals/idehdsettings/Maxtor72.pdf
