HP Compaq nx8220 Notebook Logo
Posted on May 30, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Insert smart card - HP Compaq nx8220 Notebook
binay biswas
Level 3:
Master:
  • Master 407 Answers
  • Posted on May 30, 2012
 binay biswas
Master
Level 3:
Master:
Answers
407
Questions
0
Helped
126530
Points
1160
Check sim pin bios.if any short or" open circuit check sim pin track if ok change sim ic.
Smart card stuck
Remove the power cord. Doublke-check that you removed the power cord! Use a butter knife to gently press in on the smart card in a push-to-release effort. Then insert an unfolded paper clip along the side of the smart card and try to nudge it outwards.
3helpful
Insert smart card into reader
hello,
this massage is shown only when you remove the card before closing the program,insert the card copy some file close the program properly and this massage should vanish.
Hp compaq nc6230 does not start up and say insert smart card into smart cart reader
Ok my friends, in this moment I'm fixing this problem in a compaq nc6230...The problem here is....The keyboard!! Try uninstalling your keyboard, and now turn on without the keyboard, and now you can see the message of "Insert Smart Card" dissappear!!
Says to insert smart card on my hp laptop
Your laptop is locked and will not boot without the correct smart card. It has a smartcard reader on the left side of the laptop. If there's a card in the slot, make sure it's correcly inserted.
How open in laser toner catridge make-xerox model-phaser 3100
Replace the toner: Always use the smart card provided with the new Print Cartridge when replacing the cartridge. The smart card contains the information necessary to reset the level of Toner. Replacing the cartridge without using the smart card may result in the consumable management system being inaccurate.
  1. Insert the smart card provided with the new Print Cartridge into the smart card reader. A "Change Toner?" message will be displayed.
  2. Press the [OK] button. An "Open Front Cover Replace Toner" message will be displayed.
  3. Push on the left and right side of the Front Cover and simultaneously lower the cover.
  4. Grasp the handle on the Print Cartridge, and then raise and remove the cartridge from the machine.
  5. Unpack the new cartridge, and then insert the cartridge into the machine.
  6. Close the Front Cover. A "Have You Changed the Toner?" message will be displayed.
  7. Press the [OK] button. A "Please Wait" message will be displayed while the machine reads the smart card, and then a "New Toner Remove Card" message will be displayed.
  8. Remove the smart card from the reader and dispose of the card as normal office waste.
    NOTE: If the smart card has been used with a previous installation of a Print Cartridge, a "Remove Card Already Used" message will be displayed. The smart card can only be used once. Make sure to use the card that came with the new cartridge.
1helpful
I got my lg View from a friend and when i put a sim card in it says Insert Smartchip
Cut a small piece of cardboard or credit card plastic similar in shape to -- but just a bit smaller than -- the smart chip. Place the piece on top of the smart chip. Simultaneously slide both the smart chip and the piece of cardboard/plastic into the smart chip slot. Make certain you are inserting the smart chip with the proper end inserted first and with the contacts uncovered by the extra piece (On the LG Vu, the smart chip contacts will face down and the missing corner will be showing on the outside of the slot when the card is inserted properly.). If that doesn't do the trick -- see your cell phone provider and/or get a new phone.
May 20, 2010 • Cell Phones
2answers
Eurovox max v most of the scrambled stations are saying insert smart card i have never had to put a new code in and dont know how to
Smart card is a card that is inserted into the settop box(I believe thats what you are using) so that your subscription is activated and you will be able to watch channels. If the card is already inserted Turn off the set-top box gently pull out the card and re-insert it. If problem persists or you do not have a smart card kindly contact your cable operator so that he can provide you with the same.
Says insert smart chip
smart chip means the SIM card.
try cleaning the metallic part of the SIM card with a cloth and the metal connectors on the phone with cotton bud etc.
Put it back and try again.
If not working grab another SIM card (working - friend's etc) to test.
If still not working, send to service centre.
If working for other SIM card then replace your own SIM card.
4helpful
4answers
u have not properly removed it when it is used.u insert u r card and press continue and properly remove it
Top HP Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
