What are you trying to boot from? It sounds like you selected something other than your hard drive.
When you power on the computer take note of which key it says to hit to Change the Boot Order or Boot Sequence and hit that key. This is a one time change that will get you booted up. You should select your Hard Drive to boot from.
To make the change permanent you will have to get into you Bios or System Setup. Reboot the computer and notice what key it says to hit to get into the Bios or System Setup then hit that key. When it opens up, hit the tab that lets you change the boot sequence or boot order then save it and exit out. Normally you want the DvD/CD drive 1st and the Hard Drive 2nd. This way if your system has problems you can insert a repair disk or operating system disk to fix it in the drive. The only drawback is that you need to make sure nothing is in the CD/DvD drive when you boot up (such as a music cd or movie dvd) or you will get a message telling you that it can't boot from the device.
If you like, you could just make the Hard Drive as your first boot device.
