BROKEN SPRING A spring broke on my lawn tractor. It is a yardman model 13AG601H729 When this happened I lost the accelerator pedal. I since found that the belt has slipped off the pulley, which I have fixed. I do have drive pedal for forward and reverse, but I still do not know where this spring goes. I went to the dealer and ordered a new spring. When the spring broke it was still attached to a pin, but I do not know where the other end of this spring goes? This pin is bolted to the frame and has the range to attach to pulleys under the mower, but where???? Can you help?
can you identify the spring from this?
AnonymousMar 13, 2014
Blade drive-belt has come off...how do I put it back on? It is easy to slip round the two rear "hub things it goes on but the front third one has two steel pins down either side(immobile) Do I put the belt in behind these pins and onto the hub? Doreen (75!!!!)Blade drive-belt has come off...how do I put it back on? It is easy to slip round the two rear "hub things it goes on but the front third one has two steel pins down either side(immobile) Do I put the belt in behind these pins and onto the hub? Doreen (75!!!!)
You can't post conmments that contain an email address.
