Canon PIXMA iP4200 InkJet Photo Printer Logo
A
Anonymous Posted on Apr 17, 2012
Error opening printer
Although the printer no longer exists on my computer, the print que has two documents stuck in and it will not let me remove them. Says printer does not exist
5 Related Answers
Anonymous
  • 62 Answers
  • Posted on Jan 09, 2009
SOURCE: printer document in queue will not delete
1. First, try turning printer off and on.
2. Next, on the computer side, this is how you manually clear the printer queue.
1. Go to Start, Control Panel and Administrative Tools. Double click on Services icon.
2. Scroll down to the Print Spooler service and right click on itand select Stop. In order to do this, you need to be logged in asAdministrator. At this point, no one will be able to print anything onany of the printers that are being hosted on this server.
3. Next you need to go to the following directory: C:WINDOWSSystem32spoolPRINTERS.Delete all the files in this folder. This will clear all print queues(it’s a good idea to first make sure there are no other print jobsbeing processed on any of the other printers on the server becausedoing this step will delete those jobs also)
4. Now you can go back to the Services console and right-click and choose Start for the Print Spooler service!
You can also go to a command prompt and type net stop spooler or net start spooler to start and stop the service.
I hope this helps. If you have more questions, let me know.
tbirdfan1
Michael Thomas
  • 3056 Answers
  • Posted on Aug 03, 2009
SOURCE: Can you clean maintenance cartridge and resume printing on error
hELLO THERE:
Yes you can clean the tray you may have to remove some items to be able to clean the whole tray but if you take rubbing alcohol and a eyeliner applicator you will be able to clean most of it. ok
best regards mike
Anonymous
  • 25 Answers
  • Posted on Dec 01, 2009
SOURCE: No longer prints from computer
Re-install the cd for the printer.
A Miller
  • 8404 Answers
  • Posted on Jun 14, 2010
SOURCE: printer does not print, get stuck in printer que
Delete the printer from your printer folder and reinstall the driver. Get the latest driver from www.canon.com/support
Charles A Stimeling
  • 172 Answers
  • Posted on Sep 03, 2011
SOURCE: I have my Canon MX420 printer hooked up, my
If your printer has the network cable plugged into it then your halfway there. Make sure that as well as having a hard line network cable plugged into your router, you need to connect the printer to the wifi signal as well. On your printer, push your settings button, scroll to your wireless lan setup, and connect to your router and if password protected, enter in the password and you should then be connected to you router, now try printing using your laptop or device through your wireless connection, and it should print. Please post back if you need further instructions or help!
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
