Westinghouse Electric LD4655VX TV Logo
Anonymous Posted on Apr 15, 2012
LD-4655VX blown fuse replace
  • Anonymous Apr 15, 2012
    I think the television has blown a fuse. I'm not really sure where it is located, or that the fuse is even the problem. The TV has a light on the bottom that normally lights red, then blue when it turns all the way on, now it goes red, then turns off without powering up the TV. I just figure it's the fuse. I opened it up, thinking the fuse would look similar to the ones I replace on other equipment at work, but no such luck, I'm not sure what to take out. This is just too advanced of technology for me, ha. Any help would be appreciated.
    Or just a map of the board in the back would great. I have been searching the internet for one but can't seem to find one.
Anonymous
Level 3:
Top Expert:
  • Westinghouse... Master 14,553 Answers
  • Posted on Apr 16, 2012
Anonymous
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2894631
Points
48228
Set has a conventional fuse--follow the power cord inside as it goes directly to the fuse--if power light comes on at all even for a moment the fuse is good and you may have a power supply board bad.
also look for puffed up caps on the power board that look like these=
Testimonial: "Very helpful, thank you. That isn't the best of news for me, boards are not cheap. Still, thanks a bunch, saves me hauling it all over town!"
How or where do i get a 5 digit activation code number for my ld 4655vx t.v to hook up to cable
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
2answers
Ld 4655vx fuse replace
I just fixed this same problem and it wasn't a fuse. I made a video showing how to troubleshoot and fix it.
1helpful
Get code for Westinghouse model LD-4655VX
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
2answers
Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it
hi. the led tv turn off itseft aroun 5 minutes was complete shut off or another ?? need more data???
1helpful
Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it,
If the set is still under warranty, the power supply board is going bad. If not you can replace it yourself. It's not that big of a job. You can find the parts you need at www.shopjimmy.com
Westinghouse LD-4655VX won't turn on - is my power supply broken
I just fixed this problem and it wasn't the power supply. I made a video showing how to troubleshoot and fix this problem.
Tv won't turn on Westinghouse ld 4655vx
I just fixed this problem and it wasn't the power supply. I made a video showing how to troubleshoot and repair it.
Our westinghouse ld 4655vx just shut off bye itself and won't turn back on
Check and replace its main power regulator board. It is faulty. Not working.
WESTINGHOUSE LD-4655VX CODE FOR XFINITY REMOTE
The Westinghouse LD-4655VX TV has code compatibility with Sony TVs (http://westinghouseelectronics.com/wp-content/uploads/2012/06/Remote_Codes_2012.pdf). I accidentally discovered that the Sony TV remote RM-YD040 works with my he Westinghouse LD-4655VX (because I have both TV sets).
Top Westinghouse Electric Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
Larry
ADMIN Eric
ADMIN Eric
Are you a Westinghouse Electric Televison and Video Expert? Answer questions, earn points and help others
