SOURCE: need code for direct tv for my rca remot universal control rcu600d
The product you are trying to access may be called DirecTV(different spelling). You will need to find the make of your set top box used to decode the DirecTV and then look up satelite codes in the user manual for the remote to select the correct code.
the manual for the remote can be found at
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=philipsmagnavox&dv=universalremote&md=pm435&kw=pm435s&st=&ar=&dt=&so=&pg=1&file=others/philips/pm435-manual.zip
In case you dont have the book still. Good luck.
Any drama, get back to me here.
regards
Graeme
SOURCE: rca remote control code list
OK GANG: HERE GOES, I PURCHASED A RCA REMOTE (RCR312W), 3 CHOICE FUNCTION.
SAT-CBL...TV...VCR-DVD.
I HAVE 2 DIFFERENT TV'S, DAEWOO TV AND A PANASONIC TV/VCR. THE REMOTE HAS
WORKED ON BOTH SETS. I DROPPED THE REMOTE WHEN IT HIT THE FLOOR THE BACK
FLAP HOLDING THE BATTERYS KICKED OFF AND ONE BATTERY FELL OUT. I WENT NUTS
FOR 2 DAYS TRYING TO GET THE CODE FOR THE DAEWOO. TODAY 11/14/2008 A FRIEND
GAVE ME A PANASONIC TV/VCR 20". AGAIN I TRIED TO FIND THE CODE, DIDN'T WORK OUT EASILY, AGAIN DRIVING ME LOONY TUNES IF YAA KNOW WHAT I MEAN.
HERE IS THE SKINNY: SOLUTION TO YOUR PROBLEM !!!! IT DOES WORK.
1, TURN ON THE COMPONENT YOU WANT TO PROGRAM.
2, PRESS AND RELEASE THE COMPONENT BUTTON ON YOUR REMOT THAT CORRESPONDS TO THE COMPONENT YOU WANT THE REMOTE TO OPERATE.
TV, VCR, ETC... THE ILLUMINATED ON-OFF BUTTON WILL TURN ON AND STAY ON.
3, NOW PRESS BOTH BUTTONS ON-OFF AND TV, OR: ON-OFF AND CBL. WHAT EVER.
THE ON-OFF BUTTON ON TOP OF THE REMOTE WILL TURN OFF, KEEP PRESSING
AND IT WILL COME BACK ON AND STAY ON. RELEASE THE BUTTONS,BOTH.
ON-OFF WILL STAY ON NOW.
4, KEEP POINTING THE REMOTE AT THE COMPONENT, THE REMOTE AND THE TV
NEED TO TALK TO EACH OTHER,(MAKES SENSE.)
5, GO TO THE BOTTON OF THE REMOTE AND PRESS THE "PLAY" BUTTON,
RELEASE. "" KEEP PUSHING THE PLAY BUTTON EVERY 5 SECONDS,
UNTIL THE TV TURNS OFF"". OR THE VCR, OR THE CBL, WHATEVER YOU ARE
PROGRAMING.
6, NOW: PRESS AND RELEASE THE "REVERSE" BUTTON, THIS IS AFTER THE TV
HAS TURNED OFF. TV SHOULD TURN BACK ON WHEN THE "REVERSE" BUTTON
IS PUSHED.
7, IF THIS WORKS THE LAST STEP IS TO HIT THE "STOP" BUTTON,
THIS WILL SAVE THE SETTING. REMOTE SHOULD BE PROGRAMED AND TURN
THE TV ON AND OFF. YOU DON'T NEED THE SILLY CODE NUMBER, THE REMOTE
DOES THE ACTIVE PROGRAMMING AUTOMATIC.
HOPE THIS HELPS YAA ALL... "PEACE".........OKIE
SOURCE: tv codes for a rca universal remote controller
need remote control codes for a toshiba 32A35 with a rca remote
SOURCE: I need code for rca rcr461 universal remot my tv is a ilo
1. Manually turn on the component you want.
2.Press and hold the TV, DVD etc the illuminated component names turns on.
3.While holding the compnent key down simultaneously press and hold the ON.OFF key - the illuminated name turns off.
4. After holding down both keys for 3 sec, all components name stay on.
5.Release both keys. the component name remains lit.
6.Press and release the PLAY key, wait for 5sec, the component will turn off. If component does not respont continue to press PLAY every 5 sec until component turns off.
7.When the component turns off, then the correct code is blocked. Press REVERSE key wait 2 sec to see if component turns on again.
8. Once component turns on then use STOP key - now code is stored.
Note: use FORWARD KEY AND REVERSE KEY to go front and back on the code search.
(sorry for the typo (if any) I dont have a scanner to scan the manual and I am typing out from the manual)
SOURCE: lost my manuel "codes" to my rca universal remote control crk74ba3
ineed manual code for rca universal remote for toshiba tv
