Electronics - Others Logo
Alexis Posted on Apr 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Write protected i got a new Maxell Pend Drive and haven't use it since i got it last December..last month i tried to use it to save a video and some photos but there's an error that says i cant save a file on my drive so now i just check if i could make a folder on it but i cant either and i tried to reformat it but it says i cant do it coz its write protected..any possible solution for my problem?..thanks in advance for any advice :)
Brian Sullivan
Level 3:
  • Maxell Master 27,725 Answers
  • Posted on Apr 14, 2012
Brian Sullivan
Maxell Master
Level 3:
Answers
27725
Questions
Helped
5776703
Points
79191
Click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope it helps
2 Related Answers
Anonymous
  • 35 Answers
  • Posted on Nov 21, 2008
SOURCE: Remove Write Protection
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
laikexpert
laikexpert
  • 281 Answers
  • Posted on Feb 08, 2010
SOURCE: Lexar firefly 1GB Jump Drive - Can't copy files to jump drive
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format pendrive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Top Maxell Electronics - Others Experts
Sudeep Chatterjee
Sudeep Chatterjee
ADMIN Eric
ADMIN Eric
Are you a Maxell Electronics - Other Expert? Answer questions, earn points and help others
