Electrical Supplies Logo
Posted on Apr 02, 2012
Sprinkler problem this one uses pins for day and times to start i believe this thing needs more pins there is a pin a 4pm and one at 8pm on the day but only comes on at those pins but next click next to them it shuts off
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Oct 17, 2007
SOURCE: PC: Won't Turn On
ur memory is not placed well, try removing ur memory back and place it again..
Anonymous
  • 408 Answers
  • Posted on Apr 28, 2009
SOURCE: I need the wiring diagram of pump it has 5 pins coming out of pump
hello, i holding a wiring diagram central locking system,model 201,it have a 6 pin,
  • pin no.1 brown goes to ground
  • pin .no 2 black ignition on
  • pin no. 3 red permanent 12 volt
  • pin no. 1 yellow trunk lid switch
  • pin no. 2 blue driver door switch
  • pin no.3 green passenger door switch
hoping it"s help to solve your problem,ty
Anonymous
  • 312 Answers
  • Posted on Nov 06, 2009
SOURCE: i have a vectone sim card, i had also provided a
you just enter pin code for three times so it will ask for puk code....You can call to your network provider customer care service and ask for puk code. They will give to you Such that your pin code will get reset..Hope this will help you....Thank you....
award462
Anthony Ward
  • 397 Answers
  • Posted on Jun 04, 2010
SOURCE: code does not work
http://www.fixya.com/support/r5008953-pin_codes_most_bluetooth_headsets
A
Anonymous
  • Posted on Mar 09, 2011
SOURCE: the pins on my intermatic
R8816P101C manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/r8816p101c%20-%20english.ashx
I think it is more likely sprinkler valve is stuck than timer contacts are fused together.
This is because Intermatic mechanical timers physically pull and push contacts together-apart.
Take trippers all the way out and see if that changes.
Turn off 240V circuit breaker and see if that changes.
Add a comment and let me know what you find.
Usually you see trippers worn down and the sprinkler does not turn on.
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E132?Pid=search
Or WG733-14D 240V clock motor slows or stops, then dial will not rotate.
http://store.nexternal.com/intermatic/categories.aspx?Keyword=WG733-14D&x=16&y=9
Sometimes the 133T115A toggle goes bad.
http://www.superiorlighting.com/product_p/133t1115a.htm
http://waterheatertimer.org/images/R8816P101C-1000.jpg
Top Intermatic Electrical Supplies Experts
wadingriver
wadingriver
ADMIN Andrew
ADMIN Andrew
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
