SOURCE: acer aspire 3054wxmi sound driver missing
Dear,
Please download the driver for your sound card ,from this site:
http://support.acer-euro.com/drivers/notebook/as_3050.html
Cheerup and be happy always
SOURCE: factory restore
if you can load into your current installation search for a program on your c:\ called D2D.exe it should be located within c:\Acer\ this will start a program if you click the top option it restores the factory settings.
SOURCE: restore window vista for acer aspire 5920
Hi Acer supply the restoration files in a hidden partition on your hard drive. If it is the same as mine try this. Start the pc, then while the Acer logo is showing, press ALT & F10 at the same time. Then just follow the instructions. Bear in mind that this will format your C drive so you should do a backup of any important data first. Hope this helps.
SOURCE: system restore
press ALT key and keep tapping F10 key as soon as you switch on the laptop.. keep tapping till you get to the screen where it says acer system restore
SOURCE: MY LAPTOP IS ACER ASPIRE 5315/2492 WINDOWS
it seems u have done every try.So now i recommend u too backup ur necessary files and install a fresh copy of windows via cd.
I recommend u to use xp or windows 7.
Thanks to all I will try Thanks
