Minolta DI2510 Black and White Copier Logo
Megan Martin Posted on Mar 21, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code C0910
Can't clear error code. Copier won't reset or anything.
Norman Weimar
Level 3:
  • Minolta Master 7,080 Answers
  • Posted on Mar 01, 2015
Norman Weimar
Minolta Master
Level 3:
Answers
7080
Questions
Helped
1997807
Points
12012
Second Draw lift open the second draw remove the paper from behind the draw, ALSO REMOVE THE PAPER BEING STORED ON LEFT HAND SIDE OF THE DRAW. IT IS NOT A STORAGE AREA!!!!!!! It is available for 11xx17 paper. Storage is for the storage draw!!!!!!, IF not these two items you have a bad motor for the second draw or worse case a bad control board!!!!$$$$$$
try this site for parts:
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2 Related Answers
Cogz
Chris Coughlin
  • 1326 Answers
  • Posted on Jun 27, 2009
SOURCE: Describe your Minolta Di3010 Grayscale CopHi I
The error code you are getting is a paper tray lift problem. Open all the paper trays and make sure that you have the correct size paper in each paper tray. Also, make sure the paper guides are tight againest the paper in the trays. Turn the copier OFF then back ON... Wait for the copier to come to ready and one tray at a time reinstall each tray at a time.... The one that cause's the error code to show up is the paper tray with the problem. Once you know what tray is the problem, remove the tray and look inside the copier for a wade of paper jammed behind the tray... If not you may have a bigger problem, then we can help with... Good Luck....
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Sep 06, 2008
SOURCE: Minolta Di 3010 Error code C0910
Sorry it took so long but I found it.
C0910 indicates that the 2nd drawer on your copier isn't lifting. Open the drawer and see if there is any jammed paper in there.
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
