Posted on Oct 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix the error code for Ricoh 1232c sc517 and how to clear it
  • 4 more comments
  • psda7 Oct 29, 2008
    This is a Ricoh 1232c copier
    error code is ( SC 517)
    I have a Ricoh 1232c copier
    Error code sc517
    How to fix it and how to clear the error from the memory
    I did unplug the machine for a five hours and plug it back on
    error did come back. Is there any other way I can clear the memory.
    Which is the SC517 error related to.
    Paul
  • psda7 Oct 30, 2008
    I am trying to get a fix for the error code SC517 for Ricoh Aficio 1232c copier
    can some one help to fix the problm
    and also how to clear the code from the copier
    Thanks
    The error code is SC571
    sorry for typing error
    Ricoh 1232c copier how to clear the error code
  • psda7 Oct 31, 2008
    no I am still looking for help with the problem
Anonymous
Level 3:
  • Master 507 Answers
  • Posted on Oct 30, 2008
Anonymous
Master
Level 3:
Answers
507
Questions
0
Helped
249612
Points
1453
There's no error code like that
http://www.unitedtechsonline.citymax.com/page/page/4653767.htm
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER)
384-385:IMAGE DATA TRANSFER PROBLEM WHEN TANDEM IS USED(SBU,INTERFACE
BOARD,SICU,PRINT CONTROLLER)
390:TANDEM IMAGE DATA TRANSFER ERROR(NOISE,SICU,INTERFACE BOARD)
391-392:IMAGE STORAGE ADDRESS ERROR(SICU391-01)
395:CD-R/RW ERROR, INTERFACE BOARD ISSUES
397:CD ACCESS ERROR
398:CD-R/RW DATA ERROR
400:TRANSFER BIAS ROLLER ISSUES
401:TRANSFER ROLLER
430:QUENCHING LAMP ERROR
440:DRUM MOTOR LOCKED
441:DEVELOPER MOTOT LOCKED
491:LASER COOLING FAN LOCKED
495:TONER BOTTLE PROBLEM
496:TONER COLLECTOR BOTTLE PROBLEM
501:LIFT PROBLEMS FOR TRAY 1
502:LIFT PROBLEMS FOR TRAY 2
503:LIFT PROBLEMS FOR TRAY 3
504:LCT 1ST TRAY PICKUP OR LIFT PROBLEM
505:LCT 2ND TRAY PICKUP OR LIFT PROBLEM
506:LCT 3RD TRAY PICKUP OR LIFT PROBLEM
510:PAPER FEED MOTOR PROBLEMS
511:LCT MOTOR PROBLEM
515:TANDEM REAR FENCE MOTOR PROBLEM
520-521:DUPLEX JUGGER MOTOR PROBLEMS
531:FUSING DUPLEX MOTOR LOCKED
532:RELAY MOTOR LOCK
541:OPEN FUSER THERMISTOR
542:LOW FUSER TEMPERATURE
543:HIGH FUSER TEMPERATURE
544:HIGH FUSER TEMPERATURE
545:HIGH FUSER TEMPERATURE
546:LOW FUSER TEMPERATURE
547:ZERO CROSS PROBLEM
550:WEB EXPIRED
591:TONER SUPPLY MOTOR PROBLEMS
592:TONER BANK MOTOR PROBLEMS
601:SBICU TO SBU COMMUNICATION PROBLEMS
602:SBICU TO HARD DISK DRIVE BOARD COMMUNICATION PROBLEMS
620-622:SBICU TO ADF COMMUNICATION PROBLEMS
625-626:BCU TO FINISHER COMMUNICATION PROBLEMS
630:LINE ADOPTER TO CSS CENTER COMMUNICATION PROBLEMS
640-645:BCH TO SICU COMMUNICATION PROBLEMS
646:SICU PROBLEM
650-653:COUNTER ERROR JAPAN
701:ADF P/U ROLLER PROBLEMS
702:ADF FEED MOTOR PROBLEM
703:ADF TRANSPORT BELT MOTOR PROBLEM
704:ADF EXIT MOTOR PROBLEM
705:ADF ORIGINAL TABLE LIFT ISSUES
720:FINISHER LOWER TRANSPORT MOTOR ISSUES
722:FINISHER JOGGER MOTOR ISSUES
724:FINISHER STAPLER HAMMER PROBLEMS
725:FINISHER STACK EXIT MOTOR PROBLEMS
726:FINISHER SHIFT MOTOR PROBLEMS
727:FINISHER STAPLER ROTATION PROBLEMS
729:FINISHER PUNCH MOTOR PROBLEMS
730:FINISHER STAPLER MOTOR PROBLEMS
735:FINISHER PAPER STACK PLATE MOTOR PROBLEMS
736:FINISHER EXIT GUIDE MOTOR PROBLEMS
737:FINISHER FULL STAPLER HOPPER
738:FINISHER SHIFT TRAY LIFT MOTOR PROBLEMS
739:FINISHER FOLDER PLATE MOTOR ERROR
740:FINISHER FRONT SADDLE STITCH STAPLER MOTOR PROBLEMS
741:FINISHER REAR SADDLE STITCH STAPLER MOTOR PROBLEMS
742:FINISHER JOGGER SIDE FENCE MOTOR
750:COVER INTERPOSER BOTTOM PLATE MOTOR PROBLEMS
800:VIDEO OUT TRANSFER,CONTROLLER BOARD
804:VIDEO OUT TRANSFER,CONTROLLER BOARD
818:OPTIONAL BOARD,CONTROLLER BOARD, SYSTEM PROGRAM
819:BAD SOFTWARE
820:CONTROLLER BOARD OR SOFTWARE
821:CONTROLLER BOARD
822:HDD PROBLEM
823:NIB, CONTROLLER BOARD
824:CONTROLLER BOARD, NVRAM
825:NVRAM ERROR
826:NVRAM
827:CONTROLLER BOARD, RAM
828:SOFTWARE,ROM,CONTROLLER
829:RAM, CONTROLLER
835:CONTROLLER,CENTRONIC LOOPBACK CONNECTOR
836-837:FONT DEVICE
838:CONTROLLER BOARD
850:IP ADDRESS,CONTROLLER BOARD,NIB
851:1394 I/F CONNECTIONB,I/F INTERFACE,CONTROLLER BOARD
860-861:HDD
862:HDD BAD SECTORS
863:HDD
864:DATA TRANSFER ISSUES
865:HDD
900:NVRAM PROBLEM.ELECTRICAL COPY COUNTER
901:MECHANICAL COUNTER ISSUES
921:IMB, BICU FAILING
922:IMB, BICU FAILING
924:DRAM,BICU,IMB FAILING
925:BICU, IMB FAILING
926:BICU, IMB FAILING
951:F-GATE SIGNAL ERROR PROBLEMS
953:SCANNER IMAGE SETTING ERROR ISSUES
954:PRINTER IMAGE SETTING ERROR ISSUES
955:MEMORY SETTING ERROR ISSUES
964:PRINTER READY ERROR ISSUES
966:POLYGON MOTOR PROBLEM
970:SCANNER READY ERROR
980:HDD ACCESS ERROR
981:BICU, NVRAM
982:HDD CONSTRUCTION ERROR
984-987:HDD DATA TRANSFER ERROR
990:SOFTWARE PERFORMANCE ERROR
991:REBOOT SOFTWARE ERROR
997-998:DIMM, RAM ERROR
999:PROGRAM DOWNLOAD ERRORS
  • Anonymous Oct 30, 2008
    according to this error code manual there's no such thing
    http://www.manuals4you.com/weekly/Ricoh-... Error Codes.pdf
    according to others it's "Fuser oil overflow"
    It seems the fuser oil in the tray under the fuser all runs to one side but, if I recall correctly, the sensor is in the bottom tray of the fuser. I usually use post-it notes to level the printer. It's easy to get just the right amount of lift by sticking a pad(or part of one) under the feet of the printer on the low side.
  • Anonymous Nov 01, 2008
    go to this page
Anonymous
Level 3:
President:
  • Master 1,952 Answers
Anonymous
Master
Level 3:
President:
Answers
1952
Questions
0
Helped
710682
Points
5794
Technical problems with .., help you understand error messages and questions relating to ... http://www.ricoh.co.uk/KBase/index.cfm
    Restart the OS.
    If it happens again after the restart, contact your local service representative.
Anonymous
Level 3:
Brigadier General:
  • Master 3,614 Answers
  • Posted on Oct 29, 2008
Anonymous
Master
Level 3:
Brigadier General:
Answers
3614
Questions
24
Helped
1033831
Points
10054
Try to unplug the unit for at least for hours. this will reset the last setting have made on the unit before the problem occurred.
let me know.
  • Anonymous Oct 29, 2008
    well if you still have access on the menu setting. you can either reset the unit remotely there.
Anonymous
Level 3:
Genius:
  • Master 1,142 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1142
Questions
6
Helped
452065
Points
3128
May i know the exact error message you get on the printer
Anonymous
Level 3:
Guru:
  • Master 558 Answers
Anonymous
Master
Level 3:
Guru:
Answers
558
Questions
16
Helped
227688
Points
1386
Try to reinstall the Printer, although it is a cumbersome task to get reinstall it, but let it try:
If you dont have the Setup CD for printer use this link:
Ricoh 1232C
Also read the instructions given by me in this link: Printer Tips n Tricks
Also look out the FAQ provided by RICOH : FAQ and put a question
Let me know if you need further assistance.
2 Related Answers
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Nov 06, 2008
SOURCE: For Ricoh 1232c copier error SC517
See previous threads on how to clear.
Anonymous
  • 81 Answers
  • Posted on Jul 07, 2009
SOURCE: Copier Ricoh 1232c error code sc517
"yellow clear" then press 1 0 7 and hold down stop.. go into copy sp and enter 7 8 0 7 and then press " # " press the execute button.. when it says done power down from the red switch.. then power back up.. that will clear the error.. but you may need parts if the error returns
Top Ricoh Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
