The DECserver does not have a load host to provide the DECserver (DNAS) software. Was this product used in a VMS environment and now it has been removed?
There are 3 methods to format the phone
IMPORTANT: back up your phone and memory card first!
First: if the phone menus work there is a; go to menu -> tools -> settings -> general -> factory restore.
note: the defualt code is 12345
Seconed method requires you to enter these into the dial number area.
Nokia Code : *#7370# : NOKIA Format phone (Soft Reset) Nokia Code : *#7780# : NOKIA Factory Reset (Hard Reset) Found these in the N95USERS fourm.
Note: the defualt code is 12345
Third: is a button combination the needs to be done during the phone powering on
Hold down. 3, * and Green Call button
While holding this combination press the power button once to start the phone
Note: this does not require any codes; if this works the phone will prompt you to be set up again
None of these methods format the memory card
There are two methods to format the memory card
First: Go to menu -> tools -> utillites -> memory -> options -> format mass storage
Seconed: Connect your phone to your PC via the supplied USB cable.
Then select Mass Storage mode on the phone.
Once you PC has installed the Mass Storage device you can format the card from My Computer.
Note: assuming Microsoft Windows XP or VISTA.
Billman87
