I hope you are doing well.
If this color laser printer has the fuser on forward facing part of the printer. ( I forgot the model at the moment) Could tell me or send a URL on how to replace the fuser?
In advance, "thanks" for your help.
Best regards,
Paul M
How do you reset fuser on a dell 5110? replaced fuser but still tells me to replace
Hi Paul,
If this is a 5100, then the replacement of the fuser is quite simple.
1) Before removing the fuser:
CAUTION: The fuser reaches extremely high temperatures during operation. Allow for adequate cooling time after the printer is powered off, before removing the fuser.
2) Lift the two fuser assembly locking levers.
3) Grasp the two fuser handles, and then lift the fuser out of the chassis.
Why The Dell Printer Offline Error Fuser Occurs?
§There can be issues with Printers and Devices in the control panel thereby leading to the problem at hand.
§There can be issues with the Printer Settings resulting in the particular error.
§Issues with the Printer Driver can also cause this Dell-related error code.
§There can be some connectivity issues with your Router or Modem that are probable causes of the Printer Offline error code.
§Issues with hardware and software can also prevail thereby causing several printer errors repeatedly.
§Communication issues, resulting from Antivirus or incorrect Firewall settings.
§Incorrect IP Address sometimes results in such issues.
For More Info Do Visit Us: Dell printer offline
Or You Can Call Us: +1-888-633-7151
Here is a video explaining how to install the 5110 Fuser. To anyone doing this remember that the 5100 and the 5110 fusers are different and although they look similar they are not compatible.
How long the fuser last! How many copies?
Claude.
