Torque setting for head bolts
SOURCE: head bolts torque settings
According to my haynes manual for G-S reg, 1989-1998 it goes as follows,
Stage 1:- Tighten all bolts by hand until bolt heads just contact cyl. head.
Stage 2:-Tighten all bolts to 40Nm or 30lb ft.
Stage 3:-Angle tighten all bolts a further 60 degrees.
Stage 4:-Angle tighten all bolts again a further 60 degrees.
Stage 5:- M12 x 140mm bolts ONLY angle tighten a further 20 degrees.
Hope this helps everyone, sorry it seems longwinded but that is how it's written in the manual.
SOURCE: head bolt torque
Hi bengriffith1
You can download a copy of the engine manual from here
It has all the info you need. Any problems with the download just let me know
regards
robotek
SOURCE: Torque pattern
I went to my local Tractor Supply store and they had 1 manual that covered my tractor. It had the torque pattern in it. I purchased a torque wrench while I was there and went home and installed the head myself. First time I ever tackled a job like this. After assembling all the other parts and giving the breather a little shot of either, it fired right up , hooked a set of 3 plows to it and put it to work. Thanks for your interest, Donald
SOURCE: head bolts torque settings for dogde neon 2002
assuming this is the "C" engine 8th digit on VIN plate. Use new bolts. torque first step to 25lbs, 2nd 50lbs, then 3rd 50lbs, then 1/4 turn.
SOURCE: I need to the know the head torque settings on a
I think you may have to contact massey ferguson
