ValuSoft Hard Truck: 18 Wheels of Steel for Windows Logo
Posted on Oct 12, 2008
Installing i cant plat game it wontinstall on wimdows vista
  • 2 more comments
  • Anonymous Dec 28, 2008
    I get "please run autorun.exe from the CD"... :-(
  • fish-iguana Jan 27, 2009
    I have the same problem. The solution given does not work (nice try, though). For me, the game opens fine, but once you click "install", it loads for a few seconds, and then nothing happens. I'm not sure why this is.
  • hal wilkey Feb 15, 2009
    the game install and play opening title and credit but once press any
    of the buttons to play it will say set up not done correctly.
  • Anonymous May 11, 2010
    What happens when you insert the disc?
jwalant
Level 1:
  • Contributor 17 Answers
  • Posted on Oct 22, 2008
jwalant
Contributor
Level 1:
Answers
17
Questions
0
Helped
22181
Points
53
The game was released back in 2002, that means it was designed for older versions of Windows OS (Windows 98/ME/XP). The updates for the game do not have any patches for the installation to be compatible to the new Windows Vista OS as they were released on November, 21st 2002 aslo that patches resolve functionality issues after the game is successfully installed.
Some game ".exe" file (executeable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
There are lot of files that need to be changed in order to get full functionality and to communicate with operating system and the hardware, hence there is no guarantee that the game might run even in cases where you will successfully install an older version of the game with the above mentioned steps.
The same set of steps can be used for installation of older games installation on Windows Vista.
Top ValuSoft Video Game Consoles & Games Experts
john h
James Wishart
Anonymous
Level 1 Expert
Are you a ValuSoft Video Game Console and Game Expert? Answer questions, earn points and help others
