Maytag Bravos MTW6600T Top Load Washer Logo
art clemons Posted on Jan 10, 2012
What does code dl mean - Maytag Bravos MTW6600T Top Load Washer
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Jan 19, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
4579
Points
12
The "dL" error code means that the door/lid can't lock. Check to make sure nothing is stopping the lid from closing and locking. If everything looks ok, then you either have a bad door lock or a bad control board.
What does F --DL code mean
with out a make or model number I think this code means problem with the door lock
https://www.hunker.com/13410537/how-to-fix-a-dl-or-f-error-on-a-whirlpool-duet-washer
https://www.youtube.com/watch?v=_BsaIsSlxNY
Dl f error code kenmore 11045081400 washer. what does it mean?
Here is a youtube video , you code has to do with door lock assembly ! Troubleshooting and Repairing an dL Error Code on Whirlpool Duet Washer . your washer is the same as this . Kenmore is built by whirlpool !
2answers
Maytag Brovo 300 seies washer display says dl and will not wash
The error code "dl" is for door lock. From what I've read, it may mean you need to replace the latch assembly.
2helpful
Door is locked dL error code
DL error code means the door is locked. The door lock mechanism may need to be replaced. I would not recommend attempting this on your own I suggest you call a service tech.
2helpful
Dl code
DL code means there is a problem with the door latching system, check the switch
Error code DL...
DL indicated a door lock failure. it will flash DL, then a F followed by a number (80, 82, 84, 85)
1helpful
I am getting an DL F code on my front loader
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Top Maytag Washing Machines Experts
jdthefixer
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
