Computers & Internet Logo
Anonymous Posted on Jan 02, 2012
Need Help With Bluetooth!
Right, I have a Dell Dimension E520 with this bluetooth bundle pack and it was all fine, however until last week it went all balls up, the tray icon has turned red and not green and is not connecting to other bluetooth devices. I right click and is say's 'Activate Bluetooth using Fn+F2 or Radio On/Off Switch. Can anybody help?!
Walter H Boehm
Level 3:
  • Dell Master 998 Answers
  • Posted on May 06, 2014
Walter H Boehm
Dell Master
Level 3:
Answers
998
Questions
0
Helped
346291
Points
2289
It's telling you to turn on the "radio switch" by pressing the <FN> key next to the spacebar and depressing the <F2> key.
4 Related Answers
Anonymous
  • 43 Answers
  • Posted on Jan 05, 2009
SOURCE: fn button fujitsu siemens li1705 not working
Pressing fn-F2 is telling your wireless utility software to activate/deactivate your wireless card. You should also be able to do it through your wireless utility software. There is Usually a little icon for it at the bottom-right of your screen.
Anonymous
  • 700 Answers
  • Posted on May 14, 2009
SOURCE: A problem regarding bluetooth generic adapter
Uninstall the driver. Shutdown the unit then insert the bluetooth adapter and then reinstall driver.
If not then check settings of your firewall or antivirus.
Hope this helps you already.
Anonymous
  • 137 Answers
  • Posted on Sep 03, 2009
SOURCE: Dell Dimension E520 has
Shutdown the system and disconnect the power cable.Disconnect external peripherials.Hold the power button for 10 secs to drain static power.connect the power cable to the computer.turn on the computer and hit the F2 key to boot in bios.If you are in the bios turn on the caps lock,scroll lock, and numlock key.then Hold the Alt key + E, then Alt key + F, Alt key + B. Computer will restart check for hdd or boot device.If hdd is detected it should boot to desktop.If issue persist .Shut down the system.disconnect power cable.Hold power button for 10 secs.Open the tower and disconnect the hdd from the sata or ide cable.Connect hdd in a different sata or ide connector.Connect power cable and turn on the computer and follow steps 1.If still getting same error possible hdd gone bad.Good Luck.
Anonymous
  • 561 Answers
  • Posted on Feb 13, 2010
SOURCE: IDE Device Failed on Dell Dimension
Hi
Thank you for your query
From the error message that you are seeing you are having a issue with one or both of your IDE devices. These devices are your Hard drive or/and your CD/DVD drive
I would not recommned that you tackle it yourself if you have no PC engineering experience
Please book into a reputabe firm for further diagnosis, it may be that you may need to discoonect the IDE drive from the devices and give it a clean or alternativley one of the devices may be faulty
If this has been useful please leave positive feedback/vote/testimonial as
this will help me greatly - Thank you again
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
