Coby Kyros 716829701508 Tablet PC Logo
ann johnston Posted on Dec 01, 2011
Where is the underscore key - Coby Kyros 716829701508 Tablet PC
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1566
Points
9
Shift and Hyphen (just to the right of the 0)
How do i understood its on kindle fire 5th generation and how do I remove or stop underscoring?
if u wanting see if its on 5th gen go into settings and down to about then press that and it will tell u
2answers
How can I transfer music from a flash drive like leaf bridge to my iPad Air and then have that music stored in iCloud?
You can attach some flash drives to Apple's $29 iPad Camera Connection Kit. (If you have an iPad with a Lightning connector you'll additionally need Apple's $29 Lightning to USB Camera Adapter.) Let me underscore some. Some flash drives require more power than the iPad can provide and won't work.
For the second question, here's also a guide to help you back up iPad music to iCloud.
  1. Connect your iPad to a Wi-Fi network.
  2. In iOS 8 or later, tap Settings > iCloud > Backup. ...
  3. Make sure that iCloud Backup is turned on.
  4. Tap Back Up Now. ...
  5. Make sure the backup finished by tapping Settings > iCloud > Storage > Manage Storage, and then select your iPad.
If you have a new computer, you can also backup iPad music onto it.
http://www.leawo.org/tutorial/how-to-sync-iphone-to-new-computer.html
How do I underscore from keyboard without key
On my on-screen keyboard, it's on the numeric keypad, just to the left of the space bar.
How do you find underscore on asus keyboard
in your keyboard check a sys key. clcik it and you find underscore
sign...
How to do hard reset on hcl me champ tablet?
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use theVolume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
How to type an underscore
Ok so this is a step by step guide.
1.)Open keyboard in any app.
2.)Click the ?123 button and find it here. c43fb3c0-bd7d-43a0-9a70-2fa607f54243.png 089de2a1-e8cb-40e9-a789-ed893d65eb7f.png
2helpful
Where i the underscore key on the kindle paper white
Can't remember off the top of my head but fairly sure there is a 123 button bottom left of the keyboard that changed it from text input to numeric/symbol input.
2helpful
My WritePad app for IPAD no longer separates words. Help, please?!
If the spacebar on the keyboard isn't there (with .com and underscore keys etc instead), you're in the URL-typing keyboard instead of the normal one. Try clicking the @ icon in the bar just above the keyboard to change modes. In handwriting mode, it's the same thing...click the @ icon near the left side of the bottom bar.
1helpful
In my email addressfor access to appslib has an underscore, and my Kryos does not show one on the tablet screen, any idea how to overcome this.
Press the ?123 button on the bottom left hand side of the keyboard. Then press the ALT key. This will bring you to the second screen of symbols. The underscore ( _ ) key is in the middle of the keyboard. Hope this helps :)
Top Coby Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
Kolbrun...
ADMIN Eric
ADMIN Eric
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
