Refrigerators Logo
Anonymous Posted on Nov 21, 2011
HOW TO I REMOVE THE OLD ICEMAKER FILTER? THERE IS NO KNOB OR HANDLE TO GRASP & TURN 1/4 TO THE LEFT, AS THE NEW FILTER DIRECTIONS INDICATE. IT APPARENTLY REQUIRES A SPECIAL TOOL, AS I CANNOT TURN IT AT ALL.
Richard Roth
Level 3:
Top Expert:
  • KitchenAid Master 9,472 Answers
  • Posted on Nov 21, 2011
Richard Roth
KitchenAid Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2675775
Points
28465
What is the model number of your unit? The number may be located inside the refrigerator section.
  • 1 more comment
  • Anonymous Nov 21, 2011
    MODEL #KSCS25FTSS02
  • Richard Roth
    Richard Roth Nov 21, 2011
    Remove the cap from the water filter. There will be a black button the you will need to push to be able to pull the filter out from your unit. Here is a exploded diagram of your unit. The filter is number 28 on the diagram and the button I referred to is number 26.
    http://www.appliancepartspros.com/partse...
    Let me know how it goes!
    Richard
  • Richard Roth
    Press the eject button to release the filter from the base grille.
    Pull the filter straight out.
    Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter.
    5
    Align the ridge on the cap with the arrow on the new filter and
    turn the cap until it snaps into place.
    6
    Remove the protective covers from the O-rings. Be sure the O-rings are still in place after the covers are removed.
    7
    Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
    8
    Flush the water system. Use a sturdy cup or glass. Depress and hold the
    water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat this process until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever. Hold down for 5 seconds and then release for 5 seconds. Do this on/off process for about 2 minutes. This will flush air from the filter and water dispensing system.
Top KitchenAid Refrigerators Experts
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
