The DV6000 is a moniker for an entire series of laprop computers, each with a unique model number that has some variation the DV6XXX. Some will have Intel Core Duo, some Intel Celeron, some AMD Turion 64, and some AMD Mobile Sempron processors. Features, speed, and cost will vary appropriately with the Obviously the AMD and Intel boards are different and you cannot swap processors between boards. Here is a link to the HP Maintenance Manual for the DV6000 series laptops. It lists all the Mainboards used with the series and what processors go on them. It is useful for ordering replacement parts and gives instruction on disassembly and repair.
http://h10032.www1.hp.com/ctg/Manual/c01035677.pdf
SOURCE: swap from an intel cuw-am motherboard to amd mcpsp m2
How many holes on the power-block on the old motherboard?
How many holes on the power-block on the new motherboard?
Examine the sides of the old and the new power-blocks.
One side should be smooth, and one side should have a "bump",
in order to hook to the "finger" on the power-connector.
Align the "finger" with the "bump".
Also, notice that the holes in the power-block are not "square"; they are D-shaped, to ensure that ONLY the correct posts on the power-connector will fit into the correct slots on the power-block.
SOURCE: can we change motherboard in HP dv6000?
what are my options on my wifes dv6000 mothermoard replacemnet. we are current having problems with the wireless not coming online.
Also i have the problem with dv6000 motherboard. Since my graphic chip died, i've bought a new one motherboard, but it's Intel now, not AMD. Since durring replacement, i've had problem with Wireless card, the motherborad couldnt recognize it and also my keyboard cable aint same, i think it has difference connectors, so it wont work. I have connected my USB keyboard so i have started the System setup. The setup was taking so long ( around 1h ) and still didnt finished. Any idea is there any way to do anything about that ? i mean compatibility between those two motherboards Intel and AMD, or should i search for another AMD
